Posted: 2020-07-04 10:40 PM . Last Modified: 2024-04-04 02:48 AM
Hello community,
Our customer wants to know why the floor plenum gives different results for same downflow cracs. In screenshot, you can see the top side of the airflow is red and bottom side is yellow. All cracs has the same values in their configuration.
Thanks in advance,
(CID:134026124)
Hi Erhan,
Airflow may also depend on the location of equipment in the setup. Equipment (and there location) located at top are not the same as equipment located at bottom, so the airflow in those regions may not be the same (even though there could be identical CRAC's).
Kind regards
(CID:134026150)
Posted: 2020-07-04 10:40 PM . Last Modified: 2023-10-22 02:06 AM
