Floor PDU And Rack PDU In Different Rooms
  • EcoStruxure IT forum
  • Floor PDU And Rack PDU In Different Rooms
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 04:43 PM . Last Modified: ‎2024-04-08 12:28 AM
770
Have noticed that an in rack PDU cannot be connected to a floor PDU (distribution board) unless it is in the same room.  This is a change from previous versions (not quite sure when it happened, v7.X was fine).
Apart from moving the floor PDU into the same room and connecting it to the rack PDU then moving it back out of the room is there another way to connect the two?
Would like to see this feature reversed.
(CID:120130242)
  • Data Center Operation
770
Hi James,
This is expected to be fixed in the next version - I will keep you posted & will let you know as soon as it is available, thanks.
Kind regards
(CID:120130396)
Replies 4
771
Hi James,
Kind regards
(CID:120130396)
thanks Jef Faridi.
(CID:120130855)
Posted: ‎2020-07-03 04:43 PM . Last Modified: ‎2024-04-08 12:27 AM
You are most welcome, James
Kind regards
(CID:120130862)
Posted: ‎2020-07-03 04:43 PM . Last Modified: ‎2023-10-22 02:06 AM
