Failed to update Gateway using EcoStruxure IT Web interface
  • Failed to update Gateway using EcoStruxure IT Web interface
129
72
Posted: ‎2020-07-05 08:14 PM . Last Modified: ‎2024-04-03 01:17 AM
1197
  I tried to update EcoStruxure IT Gateway from EcoStruxure IT Web interface.
I pushed "Update" in the below but failed. Does anyone know what cause this?
I tried 2 cases using the "Update" button on EcoStruxure IT Web interface but both cases are failed.
  • 1.6.0.39 => 1.6.1.9 (Failed)
    Log file: console_16039withoutIPaddress.log (06/24/2019:16:37:40.440~)
  • 1.5.2.28 => 1.6.1.9 (Failed)
    Log file: console_15228withoutIPaddress.log (06/24/2019:17:31:03.981~)
Both cases are failed with the same error message.
  • Uncaught exception in stage DceUpdateApplyStage processing command AutoUpdateCommand java.lang.NullPointerException
[Others]
  • I also tried to update using EcoStruxure IT gateway installer locally, then both cases are successes. ("EcoStruxureITGateway-1.6.1.9-windows.exe")
    • 1.5.2.28 => 1.6.1.9 (Success)
    • 1.6.0.39 => 1.6.1.9 (Success)
  • I uses the Gateway with proxy setting.  ("Configure manually")
  • I also found the file below but there is no record in it.
    C:\Windows\temp\EcoStruxureITGateway-1.6.1.9-windows_**********************.log
Akihiro
(CID:145851449)
  • IT Expert
Replies 5
1197
Akihiro Yamagami can you please go to the EcoStruxture IT Support page and in Help Center and "Submit a ticket"
Please include the Organization and Gateway Serial, these are needed to see history and gather logs, so we can diagnose this problem
(CID:145851897)
Hello Ralph,
 Thank you for your support. I have posted the ticket right now. Please confirm.
Akihiro
(CID:145851978)
I got an answer separately.
I'd like to share the summary of it for the members who have interest.
  • This issue is already recognized by the development team.
  • Current work around for this is to do the downgrade and run the upgrade manually.
(CID:146277164)
Just for sharing information.
I tried this upgrade Gateway from 1.6.1.9 to 1.6.2.14 (Windows). It also fails.
(CID:148343571)
Posted: ‎2020-07-05 08:14 PM . Last Modified: ‎2023-10-22 02:05 AM
