Posted: 2020-07-02 10:54 AM . Last Modified: 2024-04-10 12:43 AM
could you please help me to know for which reason "Apply Firmware Udaptes..." does not work via DCE?
error message: "Failed to update device: unable to transfer AOS 6.2.0."
more info:
DCE version 7.2.6
"StruxureWareDataCenterExpertFWCatalog.zip" loaded in DCE manually
Perhaps some trick/suggestion for "Device File Transfer Settings" ?
Thx&Brgds,
Massimo
(CID:94601618)
Hi Massimo,
Like Scott stated, DCE uses either FTP or SCP to transfer the upgrade files from the DCE server to the network management card. Being that FTP/SCP is an administrator privilege, DCE would require the Administrator account credentials. I would recommend the following
Please let me know how you make out.
Thank You
Victor
(CID:94601849)
Hi Massimo, we will investigate it, thanks for sharing.
(CID:94601642)
Hi Massimo, have you logged into the device and ensured that the FTP server is enabled? There also could be a firewall issue somewhere between DCE and the device on the specified port. By chance have you used the "APC SNMP Device Configuration" mechanism between DCE and this device or others on the same segment? The configuration mechanism also uses FTP and could rule out some of the issues that could cause what you're seeing.
(CID:94601732)
Hi Scott, this mean that it is NOT possible to upgrade devices fw using the secure protocol as scp ?... this is a very important point... Brgds, Massimo
(CID:94601789)
Hi Massimo,
Thank You
Victor
(CID:94601849)
Posted: 2020-07-02 10:55 AM . Last Modified: 2024-04-10 12:43 AM
Hi Victor thanks for your input.
I've tried to enable FTP on NMCs and it worked only in one case ...
Do you have more suggestion about this ?
Brgds,
Massimo.
(CID:94602937)
Posted: 2020-07-02 10:55 AM . Last Modified: 2023-10-31 10:58 PM
