Exclude search items
  • EcoStruxure IT forum
  • Exclude search items
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:20 PM . Last Modified: ‎2024-04-09 02:00 AM
635
In DCE, There is an active search bar for almost anything. Which is great! However, is there a way to use the search bar to exclude items? and/or search for multiple separate items at once?
I am trying to exclude the "Informational" Severity items in the "Active Alarms" tab. I want to show all other Severities. Is this possible?
J
(CID:105457061)
635
"Boolean operators" is your friend - Per the help documents. - see below quoted from it…basically, just type NOT inform (short for informational) - that will exclude anything with inform in the name...
"Search" field
Use the Search field to filter the list based on text you type.
You can broaden or narrow your search using the Boolean operators AND, OR and NOT. For example, you can search for UPS AND On Battery; PDU NOT Phase 1; Humidity OR Temperature; Humidity OR Temperature NOT UPS.
Only items that contain the text you specify in the Search field are displayed. When the results of a search are displayed, the background of the search field is shaded. When you clear the search field, the background shading is removed and all items are displayed.
Note: Search fields support the Boolean operators AND, OR, and NOT only."
(CID:105457067)
Replies 4
636
"Search" field
(CID:105457067)
Thank you both for your answers. I tired that however I didn't capitalize them. Stupid me.
(CID:105457106)
Hi John,
You actually can do this (for the most part).  If you type "NOT Informational" into the search bar it will exclude any alarm in the list with the severity or description with Informational in it.
The reason I say "for the most part" is that there is a slight chance that the Alarm Description of a non informational alarm would have the word "Informational" in it, and in this case it would be hidden as well.  I think it's pretty rare that this would happen though.
-Scott
(CID:105457068)
Posted: ‎2020-07-02 06:20 PM . Last Modified: ‎2023-10-31 10:58 PM
