Excel import ExoStruxture IT Advisor not working?
  • Excel import ExoStruxture IT Advisor not working?
126
65
Poelsen
Poelsen
Cadet
Posted: ‎2025-10-03 03:07 AM
225
Hi
EcoStruxure IT Advisor.ini has been edited to allow excel import
(Hashtag removed from #-Dexcel.importer.enabled=true)
IT Advisor app has been restarted, reinstalled and ini file re edited. windows rebooted, all to no avail.
"Import" still visible in menu.
EcoStruxure IT Advisor ver 9.5.0-23505-0ec5bb0d1
Any suggestions?
brgds
Poelsen
  • IT Advisor
Replies 5
Admiral
Posted: ‎2025-10-07 04:49 AM
197
If you leave it as it is (eg. not remove the hashtag)
then the import feature (in the menu) will not be visible.
Kind regards,
Poelsen
Poelsen
Cadet
Posted: ‎2025-10-07 01:01 PM
In response to Jef
Hi Jef
Made a mistake in my original request, I left out a "not"
"Import" still not visible in menu.
So far I have tried
editing ini file, the restart IT Advisor,
rebooted the laptop
uninstall IT advisor, edit ini file, start IT advisor
At no point was the import function visible ....
And now after 2-3 days not looking for the import function, it is visible.
Guess Good Things Come to Those Who Wait
Looking forward to trying out the function.
Kind Regards
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2025-10-08 05:46 AM
after loading the desktop client, did you click into Planning->Data center view?  If you're in the default "Operations" read only view, you will not see any import options under the file menu
Commed
Commed
Cadet
Posted: ‎2025-10-11 06:02 AM . Last Modified: ‎2025-10-13 05:55 AM
63
If the Excel import in EcoStruxure IT Advisor isn't working, it's likely because the feature is disabled by default and requires you to edit the .ini file by removing the pound sign (#) from the Dexcel.importer.enabled line. If it's still not working after editing the file, the issue could be a data mismatch in the spreadsheet, such as incorrect column headers, formatting errors, or special characters, which can be found by reviewing the import log file generated by the software. TM Menards
Commed
Commed
Cadet
Posted: ‎2025-10-13 05:54 AM
In response to Commed
TM Menards
