Error: A-Link Bus Power (Overload)
  • Error: A-Link Bus Power (Overload)
129
72
Posted: ‎2020-07-05 09:17 PM . Last Modified: ‎2024-04-03 12:52 AM
1679
Hi All
I keep getting an Alert from my NetBotz Wall Monitor 455 that says "A-Link Bus Power (Overload). The NetBotz only has 1 door sensor, 1 smoke sensor and 2 spot leak sensors connected to it. The Alert comes and goes at irregular intervals.
Does anyone know what could be causing this?
TIA
(CID:147201694)
  • NetBotz
Posted: ‎2020-07-05 09:18 PM . Last Modified: ‎2024-04-03 12:52 AM
I have seen this error occur on occasion too.
I suspect (but cannot be 100% certain) that this may be triggered by someone plugging a sensor or maybe an network cable into the A-Link port for a prolonged period, potentially causing damage to the A-Link bus.
(CID:147202211)
(CID:147202211)
Posted: ‎2020-07-05 09:18 PM . Last Modified: ‎2023-10-22 02:02 AM
