Posted: 2020-07-03 06:15 AM . Last Modified: 2024-04-08 10:52 PM
Hi, all!
We have some PM850 and 3rd party energy meter (with DDF), connected by ModBusTCP to DCE 7.4.0. Also we have DCO 7.5.0 with Insight modul licensed.
How can i create monthly report "Total active energy" with calculation "Total active energy_LastMonth - Total active energy_PreviousMonth"of of all this meters? In DCE reports we cannot make calculations. Firstly we try to associat PowerMetrs to [forexample] Generic PDU and sensor mapping. Ok we have data in DCO to make DCO_Insight report but only current data values. Historical data collect only in DCE.
Can i use insight to get data from DCE directly ? Or offer different idea to solve this problem.
Thank You!
(CID:108825949)
Hi Anton,
I'll defer to others as to what may be available in DCO but I'm unsure it has what you're looking for. In DCE, you can run reports and export the data. You can then use whatever calculation applications (such as Microsoft Excel) you wish to use. The other alternative to get the data from DCE in real time is to use the web API. This would require some coding on your part. You can't access the database directly.
Steve
(CID:108825951)
Hello Anton, I believe the module you are looking for is the Energy Cost module. Please see the link below for information. https://dcimsupport.apc.com/display/UADCO8x/Energy+Cost+Report?queryString=energy%20cost Thank You Victor
(CID:108825952)
Posted: 2020-07-03 06:15 AM . Last Modified: 2024-04-08 10:51 PM
How can this module get total active energy from Power Meter Series 800 by Schneider Electric ? Can i integrate powermetrs in DCO ?
(CID:108826031)
Hi Anton
I can't test but I recall that if you schedule a DCE report you can tick a box that will calculate the delta between start and end of month values.
(CID:108825978)
Posted: 2020-07-03 06:15 AM . Last Modified: 2023-10-31 10:56 PM
