Energy Efficiency
  • Energy Efficiency
126
65
silviolcf
silviolcf
Cadet
Posted: ‎2025-05-30 06:11 AM
406
Energy Efficiency
I'm Trying to create a Custom script on IT Advisor EE Module, but i dont know what the language used by these module.
How can i get a metric by an etl connection for example?
  • IT Advisor
JLehr
Sisko JLehr Sisko
Sisko
Posted: ‎2025-06-05 07:36 AM
Hi @silviolcf,
For a faster response, you may want to request support to discuss with an agent.
Admiral
Posted: ‎2025-06-06 04:40 AM
Hi Silvio,
The script language is javascript.
It does not appear that EE data is part of an export (or import) database in ITA.
Kind regards,
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2025-06-09 05:25 AM
Which ITA ETL tables are you importing data into?
ITA is able to auto generate some of the code used for it scripting and all you would need to due is update the return value to the function name.  For example, ITA can use data imported into the "Measurements" Table in the ETL import database.  Once populated, you would edit your ETL script, click devices, click your ETL import job for the measurements table, find a value and right click it to generate sum/average/min/max function etc and ITA would generate all the code needed to get that value.
It does look like this may be limited to the measurements table and not the breaker measurements table used by the manual power measurement import ETL job.
It's also possible to attach EE to external DB sources, but isn't needed for my example above.
https://community.se.com/t5/Database-integration/Sample-startup-script-for-database-integration/ta-p...
