Sample startup script for database integration
Database integration
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Energy Efficiency (on premises only)
  • Database integration
  • Sample startup script for database integration
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Database integration
  • Mark as Read
Picard EcoStruxureIT
‎2020-04-23 05:52 AM
You can integrate IT Advisor: Energy Efficiency with any JDBC or ODBC compliant database. To do this, you must configure a data provider in the startup script.
The configuration of the data provider, such as a database, is done in the startup script. You may need to add additional database drivers to connect to the database, if the generic drivers shipped with ITA: Energy Efficiency are not sufficient. Place these files in the folder /opt/jboss-as/server/isxo/lib on the server.
The sample script shows you how to connect to a Microsoft SQL database. The additional database drivers are located in the file sqljdbc.jar, and the class name of the database driver is SQLServerDriver. Replace these values with values of choice to integrate to other databases.
* Copyright (c) 2011 Schneider Electric.
* DISCLAIMER: The sample code described herein is provided on an "as is" basis, without warranty of
* any kind, to the fullest extent permitted by law. Schneider Electric does not warrant or
* guarantee the individual success developers may have in implementing the sample code on their development
* platforms or in using their own Web server configurations.
* Schneider Electric does not warrant, guarantee or make any representations regarding the use,
* results of use, accuracy, timeliness or completeness of any data or information relating to the
* sample code. Schneider Electric disclaims all warranties, express or implied, and in particular,
* disclaims all warranties of merchantability, fitness for a particular purpose, and warranties related
* to the code, or any service or software related thereto.
* APC by Schneider Electric shall not be liable for any direct, indirect or consequential damages or costs
* of any type arising out of any action taken by you or others related to the sample code.
* This script shows how to load the database driver for the MS SQL database.
* The file and class names will vary between database providers. Please consult the documentation of
* the JDBC driver applicable to your database system of choice for further information.
// Make the necessary classes available to the script
importPackage(com.apc.e2m.server.scripting);
// Define location of driver file
driverFile = "sqljdbc.jar";
// Add the driver to the classpath
ScriptClassPath.addFile(driverFile);
// Load the driver class
java.lang.Class.forName("com.microsoft.sqlserver.jdbc.SQLServerDriver");
