ETL import not working in IT Advisor
  • EcoStruxure IT forum
  • ETL import not working in IT Advisor
124
65
Back to EcoStruxure IT forum
jzurera
Lt. Commander jzurera
Lt. Commander
Posted: ‎2022-01-19 01:29 AM
1066
Hi team,
we had an ETL configured to import assets in DCO and after migrating to IT Advisor is not working. We are checking if something has changed in the CMDB export process, but it seems that everything is the same.
Do we have to change anything in IT Advisor? It seems that the ETL is working, but it does not import anything.
We are working with Spoon 5 in Pentaho, Can we work with a newest version? We tried with Spoon 9 and it did not work.
Thanks in advance.
  • IT Advisor
jzurera
Lt. Commander
Posted: ‎2022-01-21 02:12 AM
In response to Jef
1052
Hi Jef,
we deleted the ETL and created it again with the same configuration and now its working. So the problem has been solved.
Thanks!
Admiral
Posted: ‎2022-01-19 01:55 AM
1064
Hi Javier,
It may need to be investigated - for the privacy of the data/investigations you might want to report the issue via email (to support@ecostruxureit.com) or submit the issue via the following webform in the help center:
https://helpcenter.ecostruxureit.com/hc/en-us/requests/new?ticket_form_id=360000334353
Kind regards,
jzurera
Lt. Commander
In response to Jef
1053
Hi Jef,
Thanks!
Admiral
Posted: ‎2022-01-21 02:43 AM
In response to jzurera
Hi Javier,
Great, thanks for the update.
Kind regards,
