EMCP 4 generator integration
  • EMCP 4 generator integration
126
65
Guadalupe
Crewman Guadalupe
Crewman
Posted: ‎2022-09-26 02:39 PM
970
Hello! Could you help me, I integrated an EMCP 4 generator to the DCE but when the equipment is alarmed the notifications do not arrive and the DCE does not appear alarmed.
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2022-09-27 06:17 AM
2 reasons this could happen are as follows:
1) if you go to the the alarm configuration tab, select the device and click device alarms, do you see any pre-defined alarms there?
- if not, you will need to create threshold alarms or purchase Asset Definition Service to have the DDF updated.  You can submit a DDF request here https://helpcenter.ecostruxureit.com/hc/en-us/requests/new?ticket_form_id=360000111657
2)If there are predefined alarms, what is the polling interval for the device? you can check this in Device -->snmp/modbus device comm settings --> device scan settings.  Edit the device and lower the polling interval to 1 or 2 mins.  This way when an alarm occurs, DCE will see it in a min or 2
3) if the above is true and you still missed an alarm, it's possible it wasn't active for longer than 1 min.  This is unlikely with a generator, but possible.
