Dual SIM GSM modem supported on Netbotz
  • EcoStruxure IT forum
  • Dual SIM GSM modem supported on Netbotz
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:25 AM . Last Modified: ‎2024-04-05 02:59 AM
1196
Is anyone aware of a dual SIM GSM modem that works with Netbotz?
(CID:128068961)
  • NetBotz
Replies 10
1196
Hi Kevin,
The supported modem list hasn't been updated in a while I know but it can be found here. I'm not aware of any dual sim modems specifically.
Steve.
(CID:128069038)
Thank you Steve.
From the existing list of tested modems there is none that take dual SIMs. I was hoping someone on the community may have tried come across one that works with Netbotz.
Will see if there is any other updates from the community.
Kevin
(CID:128069045)
Hi. I am new at working with Netbotz systems and I need a modem that takes one sim and can be used with Netbotz 455 and cctv system that also works with it.
(CID:128747350)
Hi Obakeng,
You are welcome to try any of the modems list here.
(CID:128747558)
Where can I buy in South Africa, and also get installation from certified installer.
(CID:128748250)
Hi Obakeng, please get in touch with your local support on 011 254 6400 / 011 254 6694.
Kevin
(CID:128748424)
Posted: ‎2020-07-04 04:26 AM . Last Modified: ‎2024-04-05 02:59 AM
Kevin Kolobe Could you explain, what kind of functionality do you expect from the dual SIM modem? Do you want to send SMS via different network operators, based on recipients number, or something else?
(CID:128747612)
Hi Stanislav,
This is for alerting at a remote base station with unreliable GSM coverage. The client is looking some sort of redundancy in the event that the primary carrier provider is not available then there is an alternative one.
(CID:128748234)
Hey Kevin,
You might be better off using off the shelves email to SMS gateway.
Some of those gateways supports primary/secondary modem for redundancy.
Get Netbotz (or for that matter, DCE), to send short email to the gateway, wher ethe gateway will then send it out as SMS.
Chris
(CID:128748476)
Posted: ‎2020-07-04 04:26 AM . Last Modified: ‎2023-10-22 01:57 AM
