Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Dual NIC on ITA On Premise Server
  • EcoStruxure IT forum
  • Dual NIC on ITA On Premise Server
126
65
Back to EcoStruxure IT forum
jogo2020
jogo2020 Schneider Alumni (Retired)
Posted: ‎2020-05-06 09:31 AM
1102
Is it possible to multi-home an ITA On Premise server with dual IP and NICs?  This customer would like to expose the Tenant Portal through a secondary IP Address.  Are there any guides for this?
  • IT Advisor
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2020-05-06 09:57 AM . Last Modified: ‎2024-08-27 06:16 AM
1099
Instead of using a dual nic, you would set up a web proxy or some other vpn/secure access system so your customers could safely connect to the ITA tenant portal.
There is a basic setup guide here:
https://community.se.com/t5/For-DCIM-developers/Web-proxy-configuration-for-the-ITA-web-client-or-Te...
ATrabert
Lt. Commander
1100
jogo2020
Posted: ‎2020-05-06 10:30 AM
In response to ATrabert
1097
Yeah, I know that is an option but if it is better for a customer's network to have dual nics instead is it possible?
ATrabert
Lt. Commander
Posted: ‎2020-05-06 11:57 AM
In response to jogo2020
No, as far as I know, a dual nic set up is not supported. If anyone else has experience with this or can confirm otherwise please comment.
