Door switch sensor netbotz 200
  • Door switch sensor netbotz 200
128
Posted: ‎2020-07-04 07:27 PM . Last Modified: ‎2024-04-04 11:13 PM
1242
Hello!
I am searching for information about connection third-party magnetic contact door sensor to NetBotz 200.
I have tried to connect it through Sensor ports, but without results for now. I am using FM-102 normally open magnetic door sensor with 2 wires.
Which pins should I use to connect it to NetBotz and is it even possible? Maybe someone can share their experience in this question?
Best Regards,
Roberts Zemnieks.
(CID:132657070)
  • NetBotz
1241
Hi Roberts,
Sorry, we can't provide the pinouts. The stock sensors for the NetBotz devices have additional wiring in them so that the system can auto-detect them. My suggestion would be that since these sensors are usually an on/off type of sensor, you can use your sensor in conjunction with the NetBotz Dry Contact Cable (NBES0304).
Steve
(CID:132657123)
1242
Hi Roberts,
Steve
(CID:132657123)
Hi Steven,
Thank you for your quick response. I will try to find dry contact cable and see how it goes!
Roberts Zemnieks
(CID:132657144)
Posted: ‎2020-07-04 07:27 PM . Last Modified: ‎2023-10-22 01:56 AM
