Posted: 2025-07-15 08:55 AM . Last Modified: 2025-07-15 08:59 AM
Does someone have a list of all the different types of devices that we can add to IT Expert?
For example: we can add (UPSs) - Battery backups, and ( Power distribution unit's) PDU's
Can we add other devices? if so, what other devices can we add?
We would like to know if we can use IT Expert for other devices we have in our environment.
Thank you
Posted: 2025-07-16 07:59 AM . Last Modified: 2025-07-16 08:00 AM
Hi @adamsd,
Schneider Electric branded (including APC and Uniflair) UPSs, PDUs, and cooling devices are all supported and should able to be monitored. Other Schneider Electric devices, such as power meters, branch circuit monitors, and breakers, are most likely already supported.
Have a look at both the report and the device library release notes linked in this article:
https://community.se.com/t5/Gateway-FAQ/How-can-I-see-if-my-device-is-currently-supported/ta-p/44706...
You can request support for devices that are not currently supported. More information here:
Posted: 2025-07-17 07:26 AM
Can you please provide me with more details on these devices.
Can you please provide me with some model numbers? of the devices noted below. from Schneider Electric
Your help is greatly appreciated...
Uniflair devices
cooling devices
power meters
breakers,
Thank you
Posted: 2025-07-18 07:18 AM
Hi @adamsd,
You can search for device definition files (DDFs) here to get more information about models.
https://ddf.ecostruxureit.com/
The Schneider Electric devices you listed are most likely supported. To be 100% certain, you can try discovering the device in the EcoStruxure IT Gateway and look at the sensors.
If you need more details, I suggest that you submit a general support request.
