Devices lost in DCE after rebooting
  • Devices lost in DCE after rebooting
129
72
jzurera
Lt. Commander jzurera
Lt. Commander
Posted: ‎2022-08-11 04:35 AM
3718
Hi team,
in a customer with DCE 7.9.0 we have lost all the devices that were monitored in the private network after a server reboot. It was a non controled reboot, the host where the DCE virtual machine was located was disconnected to the power supply by error.
After the reboot all the devices dissapeared. The customer had to restore a backup to recover the configuration.
This is the log of the error if you could check what could happen:
10/08/22 18:41:36.974 INFO - StruxureWare Data Center Expert server version: 7.9.0
10/08/22 18:41:36.975 INFO - StruxureWare Data Center Expert server model: VIRTUAL
10/08/22 18:41:36.975 INFO - StruxureWare Data Center Expert server build: 193
10/08/22 18:41:36.975 INFO - StruxureWare Data Center Expert GUI minimum version: 7.9.0
10/08/22 18:41:38.045 INFO - Starting StruxureWare Data Center Expert
10/08/22 18:41:43.757 INFO - Dynamic root password has been set.
10/08/22 18:41:44.645 INFO - Loading Operating System information
10/08/22 18:41:44.649 INFO - Loading Modules....
10/08/22 18:41:45.508 WARN - log4j:WARN No appenders could be found for logger (org.springframework.context.support.ClassPathXmlApplicationContext).
(com.netbotz)
10/08/22 18:41:45.508 WARN - log4j:WARN Please initialize the log4j system properly.
(com.netbotz)
10/08/22 18:41:56.187 INFO - Initializing connections to the database...
10/08/22 18:41:57.907 INFO - Database connections initialized
10/08/22 18:42:00.421 INFO - mxBeanName: IsxcQueues:name=EventServiceWorkQueue
10/08/22 18:42:01.029 INFO - mxBeanName: IsxcQueues:name=EventQueueThread
10/08/22 18:42:02.143 INFO - mxBeanName: IsxcQueues:name=ACULQueuedefault
10/08/22 18:42:02.152 INFO - mxBeanName: IsxcContextListeners:name=default
10/08/22 18:42:02.465 INFO - Varlib Initializer start
10/08/22 18:42:09.917 INFO - Varlib Initializer stop
10/08/22 18:42:09.942 INFO - mxBeanName: IsxcQueues:name=VarLibPersisterWorker
10/08/22 18:42:09.955 INFO - (ISXC) Initialized
10/08/22 18:42:09.981 INFO - mxBeanName: IsxcQueues:name=ACULQueueISXC
10/08/22 18:42:09.981 INFO - mxBeanName: IsxcContextListeners:name=ISXC
10/08/22 18:42:10.189 INFO - IP Interfaces loaded
10/08/22 18:42:10.199 INFO - private network settings loaded
10/08/22 18:42:10.221 INFO - NetworkService started
10/08/22 18:42:10.591 INFO - Enclosure Bb17b3a_nbSNMPEncA2CC634F appears to be orphaned, removing.
10/08/22 18:42:10.616 INFO - Enclosure Bb17b3a_nbSNMPEnc29730E84 appears to be orphaned, removing.
10/08/22 18:42:10.616 INFO - Enclosure Bb17b3a_nbSNMPEnc818BC6CA appears to be orphaned, removing.
10/08/22 18:42:10.616 INFO - Enclosure Bb17b3a_nbSNMPEnc0D89F975 appears to be orphaned, removing.
10/08/22 18:42:10.616 INFO - Enclosure Bb17b3a_nbSNMPEnc47661CC6 appears to be orphaned, removing.
10/08/22 18:42:10.617 INFO - Enclosure Bb17b3a_nbSNMPEnc42CEDE80 appears to be orphaned, removing.
10/08/22 18:42:10.617 INFO - Enclosure Bb17b3a_nbSNMPEnc978B5F84 appears to be orphaned, removing.
10/08/22 18:4
10/08/22 18:42:18.196 ERRR - Device Bb17b3a_nbSNMPEnc4EA7FA50 does not exist, removing from group SAIs
(com.netbotz.server.services.inventory.impl.DeviceGroupServiceImpl)
10/08/22 18:42:18.196 ERRR - Device Bb17b3a_nbSNMPEncCE4387D2 does not exist, removing from group SAIs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncBC051CD8 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc41620400 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc928CF61C does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc279D373E does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncC8A1942B does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncADD5E2F4 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc3438EAFB does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc5EAF3093 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncB8A11CF1 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncD239CD84 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc23AD1B49 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc7834FB32 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc0F675768 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc775CFDBE does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEncC5371D25 does not exist, removing from group PDUs
10/08/22 18:42:18.217 ERRR - Device Bb17b3a_nbSNMPEnc7A574FAF does not exist, removing from group PDUs
10/08/22 18:42:18.238 ERRR - Device Bb17b3a_nbSNMPEnc10CB1D4C does not exist, removing from group Netbotzs
10/08/22 18:42:18.238 ERRR - Device Bb17b3a_nbSNMPEnc56E0E855 does not exist, removing from group Netbotzs
Captain
Posted: ‎2022-10-05 07:10 AM
In response to eslamsabry2230
3340
Hi folks,
Sadly once you've encountered this issue with DCE 7.9.0 or 7.9.1, there is no resolution other than re-deployment and bringing in a backup.
APC has determined the root cause of this issue however and a fix has been implemented in the new 7.9.2 release of DCE that should prevent this issue from recurring. Please contact your local tech support for links to 7.9.2. (and 7.9.1 if you're still on 7.9.0).
Steve
Replies 10
Mike-Sutton
Lieutenant Mike-Sutton
Lieutenant
Posted: ‎2022-08-11 04:52 AM
Hi Jzurera,
Have you tried rolling back the VM to its last snapshot or backup point
This should work fine
Mike
Captain
Posted: ‎2022-08-11 05:38 AM
3699
Hi @jzurera ,
I would ask that you send this in to tech support directly where they can look at logs and potentially get more info. If they were to request info such as potentially a prior backup of the system etc we wouldn't want to do that through the forum.
Steve
jzurera
Lt. Commander
Posted: ‎2022-08-11 06:51 AM
In response to APC_Steve
Done. Thanks Steve.
MuhammedElMahy
MuhammedElMahy Schneider Alumni (Retired)
Posted: ‎2022-09-14 04:18 AM
3459
Hi Jzurera,
Did you find any solutions to this issue? I'm facing the same issue right now in a customer site.
Thanks.
eslamsabry2230
Ensign eslamsabry2230 Ensign
Ensign
Posted: ‎2022-10-05 05:58 AM
In response to MuhammedElMahy
3349
Dears,
I am facing the same issue on DCE version 7.9.1 as all discovered devices missed from DCE, Have that issue solved??
Captain
3341
Hi folks,
Steve
jzurera
Lt. Commander
Posted: ‎2022-11-10 08:23 AM
3161
Hi @APC_Steve ,
with this server (DCE 7.9.0) we have had another issue. A lot of devices have dissapeared from DCE suddenly.  We have tried to add them again and it is not possible, but from DCE web page the SNMPwalk works perfectly for each device, but when we try to discover them in the DCE desktop client, they don't appear.
We have lost around 30 devices from a total of 350 devices, all are APC products (ATSs, Netbotzs, Inrows, PDUs...)
The customer has tried to recover from a backup and it did not work. I have tried to do a new backup and it failed, but the repository mount test worked fine.
I have tried to upgrade to 7.9.1, we have been waiting for 2 hours and the web page says "Espere mientras Data Center Expert se inicializa" (Wait while Date Center Expert restart).
We have entered by the console in the vCenter to check if we could see any progress in the console, but it appears to be working still in version 7.9.0, we can logon with apcesetup user and check the network configuration, but we do not see any progress in the console abput the update.
We try to enter by the desktop client and it says that "DCE server is not working"
What else can we check?
Thanks in advance.
Captain
Posted: ‎2022-11-10 09:11 AM
In response to jzurera
3158
Hi @jzurera
Once this issue occurs, you do not want to try to re-add the devices. You must redeploy. Do not try to upgrade the system as is.
You do not want to create a backup of this system at this point either.
If you have a backup from before the issue, you should be able to import that.
If you can not import a backup from an earlier system, it is indeed a different and separate issue and that would be a whole new troubleshooting.
If you started at 7.9.0 or 7.9.1, you'll want to start over again.
If you had 7.8.1 backups and you imported that to 7.9.0 and then got this issue, you want to go that route again.
Steve
jzurera
Lt. Commander
Posted: ‎2022-11-10 10:18 AM
3156
Sorry Steve, but I do not understand exactly what you mean.
We started this project in 7.9.0 and we have a backup of this version. But the customer says that the restore did not work, so I tried to do a backup only to check if it worked because the scheduled backup was not working, and it failed. So if the customer is right, we cannot restore from the previous backup.
So, do we have to create a new virtual machine in 7.9.0 and restore the previous backup that we have? Do we have another alternative?
Thanks in advance.
Captain
Posted: ‎2022-11-10 10:37 AM
Hi @jzurera ,
That's correct. You have to deploy a brand new VM.
If you have a backup from the very beginning, of the original 7.9.0 deployment (before the issue), use that backup.
Try to deploy using the same mac address so that you don't have to contact support to release the licenses from the old mac and associate them with the new mac.
If you can't import that backup into a new VM, it's possible there was an issue even before the issue we're seeing and you may want to deploy 7.9.2 (fixed version) and start from scratch.
At minimum, importing of the backup failing is a new issue and needs to go through tech support. If support can't find a resolution, we'll be back at deploying 7.9.2 and manually reconfiguring.
Steve
