Posted: 2020-07-02 02:40 PM . Last Modified: 2024-04-09 04:08 AM
Is it possible to change the IP Address of a Device that is already discovered and in use in DCE without having to re-discover it and loosing all that sensor data history?
For example, we have a UPS and need to change the IP address but don't want to lose all the history data.
Craig
(CID:99157847)
Hi Craig,
What you are asking to do is not possible, as when you change the IP address this is essentially a new device to the DCE server. What we have done in the past, is kept the old device but placed it into maintenance mode and added a comment to say that this now related to the new IP.
Kind Regards
(CID:99157888)
We upgraded to DCE 7.6.0 and this is supposed to be possible. Looking for assistance on how to do this.
(CID:137731144)
Posted: 2020-07-02 02:40 PM . Last Modified: 2023-10-31 10:53 PM
