Dco IP adresas setup
  • EcoStruxure IT forum
  • Dco IP adresas setup
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 10:30 PM . Last Modified: ‎2024-04-03 12:27 AM
559
I have only root user password, and dont set any administrator rights user over install of server. How can i set IP?
(CID:149293281)
  • Data Center Operation
Hi Darius,
Log in to server webmin interface (https://:10000), go to System > Users and Groups, and then click on the user that you've created during the installation, (apc in my test/illustration), or if needed create a new user:
And then make sure the already existing user (apc in my case) or the new user, is added to the "wheel" group, and Save:
Note: "root" log in to server has been disabled long time ago, so avoid using "root" as user name.
If you need to change the existing IP settings, then log in to server webmin interface, and go to System > Network Configuration, and select the options (such as Network Interfaces for IP change, Routing and gateway, etc.).
If the network configuration has not been carried out during the installation, then I would go for re-installing the software and making sure that it's properly configured.
Kind regards
(CID:149293307)
Posted: ‎2020-07-05 10:30 PM . Last Modified: ‎2023-10-22 01:51 AM
