Dco 8.3.2 Colo Customer
  • Dco 8.3.2 Colo Customer
127
65
Gianluca
Lieutenant Gianluca Lieutenant
Lieutenant
Posted: ‎2020-05-05 10:40 AM
1492
HI all
is there any way to modify customer properties in Dco Colo?
now to Add a customer we need to use API
Customer does't believe that there is only API to do that
thanks
  • Data Center Operation
  • DCIM Support
Captain
Posted: ‎2020-05-06 03:42 AM
In response to Gianluca
Yes.
The intention for the customers features in DCO/ITA was originally meant for colocation customers to assign ownership of assets.
When the feature was originally built we had found colocators had typically had their own customer management system in which they kept their customer information, so there was a general feeling integrations would be required, so the api's were built.
Regards
Greg Sterling
Admiral
Posted: ‎2024-10-04 06:50 AM
Hello All,
Customer's can now be managed via the web interface.  This action was previously only available via the Rest API.  See the release notes for additional information and features.
Kind Regards,
Cory
Replies 4
Valentin_Kozlov
Lieutenant Valentin_Kozlov Lieutenant
Lieutenant
Posted: ‎2020-05-05 02:03 PM
1482
Hi!
That's right, there is no other way to create customer than API.
You can use API user interface with https://<your_DCO_ip>/api/current
There is a human readable UI with requests descriptions that can be also used to send requests to server.
To update customer details you need to use GET /customer request to get "id" parameter and then use PUT /customers/{customer-id} request with received id as argument.
Gianluca
Lieutenant
Posted: ‎2020-05-06 12:49 AM . Last Modified: ‎2020-05-06 12:51 AM
In response to Valentin_Kozlov
1473
reply from customer
The fact that dco's customer are managed only via API, makes me think that it is made to be interfaced with other systems, specifically the registry. All operations of create, update etc. they are done on another system and then "synchronized" on DCO.
At this point, would it be possible to have examples of real implementations? Just because we don't have the energy to reinvent the wheel :)"
thanks
@Valentin_Kozlov
Captain
Yes.
Regards
Greg Sterling
Admiral
Hello All,
Kind Regards,
Cory
