Data Center Operations Report errors
  • Data Center Operations Report errors
129
72
Posted: ‎2020-07-03 04:57 AM . Last Modified: ‎2024-04-08 11:30 PM
711
Hi all,
Trying to run DC operations reoprts but keeps failing with :
2016-08-10 11:38:39,298 ERROR [com.apc.isxc.reports.views.ReportView] (main) org.eclipse.birt.report.engine.api.EngineException: Failed to find out data source of data set "InventoryFilterDataSet". (Element ID:8)
2016-08-10 11:38:39,298 ERROR [com.apc.isxc.reports.views.ReportView] (main) Error generating report
Including this message
!MESSAGE JVM args: [-Xms256M, -Xmx768M, -XX:+UseConcMarkSweepGC, -XX:+CMSIncrementalMode, -XX:+CMSIncrementalPacing, -XX:MaxPermSize=256M, -XX:+HeapDumpOnOutOfMemoryError, -Dfile.encoding=utf-8, -DbuildType=Release, -Dosgi.bundlefile.limit=0, -DsyncProduct=OPERATIONS, -Dosgi.nls.warnings=ignore]
Any help would be great thanks
Regards
Matt
(CID:106892349)
Replies 5
Hi matthew.broom, thanks for posting! Let's see who can be of assistance here. @community - anyone who can help Matt? Best, Stine
(CID:106892571)
711
Hi Matt,
What is the DCO version? I guess the issue might be related to apparently corrupted custom designs (that might have been migrated from previous version/solution.
You might want  to try to restore the default design. "Analytics Reports" -> "Restore Default Designs" is illustrated :
NOTE: this will overwrite and will restore the default designs, and you would loos the customized designs (if any). It is always a good practice to take a fresh backup before doing any changes.
Hope this helps,
Kind regards
(CID:107448364)
even i was facing the error with printing the reports, i did the restore it solved the issue.
Thanks jef.
(CID:111939059)
Posted: ‎2020-07-03 04:58 AM . Last Modified: ‎2024-04-08 11:30 PM
You are welcome, Waseem
Kind regards
(CID:111939072)
Posted: ‎2020-07-03 04:58 AM . Last Modified: ‎2023-10-31 10:23 PM
