Dashboard export
  • Dashboard export
126
65
Posted: ‎2020-07-03 06:46 PM . Last Modified: ‎2024-04-07 11:44 PM
1099
Dashboard export
Jef Faridi Hello jef hope you doing good
i have one query
Can we export dashboard file and import it on another machine ?
See i have created a dashboard on server using local host now the customer wants the same dashboard to be placed on the main screen of  there office i have installed Struxureware portal but building that dashboard again one by one adding portlets will take time
So the easiest way was to import the same dashboard file from server to this main screen.
Pls support if its possible how to do that ?
Thanks for you support always
Regards
(CID:123345945)
  • Portal
Hi Waseem,
Many thanks, hope you are well too.
You might want to try the backup/restore option that is described here: StruxureWare Portal backup and restore
Hope this helps,
Kind regards
(CID:123345965)
Hi Waseem,
Hope this helps,
Kind regards
(CID:123345965)
Posted: ‎2020-07-03 06:46 PM . Last Modified: ‎2023-10-22 01:49 AM
