Posted: 2020-07-03 04:20 AM . Last Modified: 2024-04-08 11:41 PM
Hi Team
When a try to import DWG file, the error attached appear:
Is there a solution ?
Rgds
(CID:106210211)
Fabio,
The file is using unsupported elements. Supported elements can be found here: https://dcimsupport.apc.com/display/public/UAOp74/CAD+Import+Supported+Entities
Cory
(CID:106210236)
Solution is to use CAD application and remove the unsupported elements from drawing. Region and Spline could be converted to polylines. I'm not sure about 3dSolid, is this a 3D drawing?
(CID:106210259)
Posted: 2020-07-03 04:20 AM . Last Modified: 2023-10-31 10:56 PM
