Posted: 2021-06-24 05:21 AM
Hi!
Anyone can help me?
I`m trying to do a backup in DCE version 7.8.1,, but, when I try to test mount I receive the message : "The Share was unable to be mounted, Please Check your settings"
i`m attaching below the images from dce backup and windows share.
DCE Backup
Windows Share
Posted: 2021-06-24 07:58 PM
HI Silvio!
You don't need to use $ symbol in share field, just share name as it printed in folder properties.
I'd recommend to create special folder for backups and do not use root directory since it is often under administrator's restrictions.
Also your user should have proper permissions on this folder.
Posted: 2021-06-25 03:10 PM
Hi Valentin!
I had already tryied this, like images below.
Posted: 2021-06-28 07:30 AM . Last Modified: 2022-10-19 01:36 AM
You might want to check out the following post for some ideas:
https://community.se.com/t5/EcoStruxure-IT-forum/Data-Center-Expert-Server-Backup/m-p/274666#M31742
Also, check out if your window's SMB v1 share protocol is enabled?
Alternatively, you may try to use NFS as another backup option.
BR,
TJ
Posted: 2021-06-29 02:30 AM . Last Modified: 2021-06-30 12:18 AM
Automatically schedule or manually create backup files for your server's configuration data, or its configuration and repository data, and use a backup file to manually restore the server data, if needed.
