DHCP logs full All devices are in failure mode
  • DHCP logs full All devices are in failure mode
126
65
Posted: ‎2020-07-04 04:38 PM . Last Modified: ‎2024-04-05 12:10 AM
860
All my devices just went into failure mode. I have seen this before when the dhcp logs filled up and couldn't store more info so they all went into failure. I thought this issue was going to be fixed in 7.4.3 (which I am running). I just check the logs on the server and I am seeing this:
4/17/18 13:49:40.979 WARN - Unable to parse DHCP lease
(com.netbotz.server.services.dhcp.impl.LeasesFileProcessor)
java.lang.NullPointerException at com.netbotz.server.services.dhcp.impl.LeasesFileProcessor.parseLeasesFile(LeasesFileProcessor.java:216)
at com.netbotz.server.services.dhcp.impl.DhcpLeaseServiceImpl.parseLeasesFile(DhcpLeaseServiceImpl.java:77)
at com.netbotz.server.services.dhcp.impl.LeasesFileProcessJob.executeInternal(LeasesFileProcessJob.java:58)
at org.springframework.scheduling.quartz.QuartzJobBean.execute(QuartzJobBean.java:86)
at org.quartz.core.JobRunShell.run(
JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:534)
Any help would be great
Thanks inadvance
(CID:130096358)
  • bug
Hi Ryan, I am seeing that this was fixed in 7.5.0, not 7.4.3. We adjusted log rotation to prevent this scenario.
Tech support can help you obtain 7.5.0 and/or clean out the logs on v7.4.3 if need be.
(CID:130096365)
(CID:130096365)
Posted: ‎2020-07-04 04:38 PM . Last Modified: ‎2023-10-22 01:49 AM
