Posted: β2020-07-03 03:52 PM . Last Modified: β2024-04-08 12:49 AM
Hi i am having issue getting sensor datas in DCE.
I have tried DCE 7.2.6/7.4.0/7.4.1 and the latest 7.4.3. All gave the same results without any sensor values but i was able to get values using modscan. I have attached the screenshot for your references.
(CID:118001581)
Mark,
I suggest you put this request to DDF team.
https://dcimsupport.apc.com/devices
I presume this is an existing DDF? When you raise, please indicate the DDF reference number there, so its easier for the team to cross reference.
Chris
(CID:118001609)
Hi Yeoh Chee Leong,
If, during the discovery of your device on the DCE-server, you correctly specify its IP address and Slave ID, then there is a high probability, that your DDF-file siemens_fue950.xml contains errors.
In this case, it is better to perform Request modification (a new feature, appeared more recently) for your device:
With best regards.
(CID:118001612)
Posted: β2020-07-03 03:52 PM . Last Modified: β2023-10-22 01:49 AM
