Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 06:05 PM . Last Modified: 2024-04-03 03:08 AM
Is anyone know where can download the DDF file for "Schneider Electric E3SUPS30KH"
(CID:140714628)
Dear Eva,
On a similar issue there are already several topics, for example:
That is, as far as I understand, in order to monitor the new Easy UPS 3S series, you need to have:
For starters, you can try without the above specified DDF-file. At the same time, the DCE-server will use the universal upsmib.xml DDF-file to monitor the above mentioned new UPS.
In any case, regarding the correct DDF-file, you better make a request on a special DDF resource.
If you have more questions, please ask.
With respect.
(CID:140714658)
Dear Eva,
With respect.
(CID:140714658)
Posted: 2020-07-05 06:05 PM . Last Modified: 2024-04-03 03:07 AM
Dear Eva,
Easy UPS 3S E3SOPT001 UPS SNMP card part number is E3SOPT001.
https://www.apc.com/shop/id/en/products/Easy-UPS-3-Series-Network-Card/P-E3SOPT001
EcoStruxure IT gateway already has the Easy UPS 3S device support. In order to monitor Easy UPS 3S on DCE software, You can request the DDF file from Device Support as Specialist mentioned.
I hope this answers your query.
Bala
(CID:140714774)
Posted: 2020-07-05 06:05 PM . Last Modified: 2023-10-22 01:47 AM
