DCO
  • DCO
127
65
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2024-04-04 11:33 PM
955
DCO
Hi there.
i would like to ask how to make wall mounted devices like DB boards to appear on the wall not mounted on the floor.
also which device should  i use from the genome library for wall mounted air conditioners because when i try to use generic overheard cooler it doesnt allow to drag to the layout.
(CID:132646933)
  • Data Center Operation
955
Hi Kedibone,
That is not supported, currently floor mounted devices can be modeled in DCO.  So you might need to use floor standing devices (as work around) and adding some custom properties to note that the device in fact is wall mounted.
And concerning the wall mounted conditioners, maybe Vertical Grilles (wall mounted) could be tried out or perhaps just using a floor standing cooling unit (as a work around).
Kind regards
(CID:132646973)
Replies 4
956
Hi Kedibone,
Kind regards
(CID:132646973)
Thank You very much
(CID:132647462)
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2024-04-04 11:32 PM
Hi Kedibone,
You are most welcome,
Kind regards
(CID:132647474)
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2023-10-22 01:47 AM
