DCO
EcoStruxure IT Forum
  • Re: DCO
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2024-04-04 11:33 PM
1339
DCO
Hi there.
i would like to ask how to make wall mounted devices like DB boards to appear on the wall not mounted on the floor.
also which device should  i use from the genome library for wall mounted air conditioners because when i try to use generic overheard cooler it doesnt allow to drag to the layout.
(CID:132646933)
  • Data Center Operation
DCIM_Support
DCIM_Support Mentor
Mentor
1339
Hi Kedibone,
That is not supported, currently floor mounted devices can be modeled in DCO.  So you might need to use floor standing devices (as work around) and adding some custom properties to note that the device in fact is wall mounted.
And concerning the wall mounted conditioners, maybe Vertical Grilles (wall mounted) could be tried out or perhaps just using a floor standing cooling unit (as a work around).
Kind regards
(CID:132646973)
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
1340
Hi Kedibone,
Kind regards
(CID:132646973)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thank You very much
(CID:132647462)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2024-04-04 11:32 PM
Hi Kedibone,
You are most welcome,
Kind regards
(CID:132647474)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 06:24 PM . Last Modified: ‎2023-10-22 01:47 AM
