Posted: 2020-07-03 05:25 AM . Last Modified: 2024-04-08 11:21 PM
Is there a way to set the DCO v8 web interface time out time to a longer time or not time out?
(CID:108234847)
Hi Chad,
Currently it is not supported for a user to change the default "timeout" (I think it is 1 hour), however a customized solution (with some developer engagement) might be an option.
I believe the option for changing the session timeout (form UI) is expected to be included in a future version.
Kind regards
(CID:108234907)
If the timeout is one hour, then i seem to be getting some unexpained session timeouts when logged into the web interface... Any ideas?
(CID:108234945)
Hi Chad, Actually the default session timeout is 2 hours (for DCO 8.0 web client). Would it be possible to ask for your server logs (collected from the webmin interface)? plus some description about your unexplained session timeouts, user name and the date/time you are experiencing the issue. That would help us to study the log files. I will send you an invite to my =S= box, just in case if you would share the data with me, thanks. Kind regards
(CID:108234967)
Posted: 2020-07-03 05:25 AM . Last Modified: 2023-10-31 10:52 PM
