DCO v8.0.1 Web client
  • DCO v8.0.1 Web client
129
72
Posted: ‎2020-07-03 07:19 AM . Last Modified: ‎2024-04-08 04:13 AM
786
I have just build a new server in Hyper V and installed the DCO V8.0.1 install and restored my Database. this all works fine, however I am unable to load the Web client in Internet Explorer due to a self signed certificate which is not trusted.
Do I need to upload my Root certificate to the DCO server so that it is trusted on my domain?
If so how do I do this?
Martin
(CID:109446967)
  • Data Center Operation
Hi Martin!
You have  two options:
  1. Easy way
You can simply add exception for your DCO server in browser settings.
2. Right way
You need to create a new SSL certificate for your DCO server signed by your company's CA or third-party CA. Then you need to replace existing DCO certificate with new one. Procedure is described here: Changing SSL certificate
I hope this helps/
(CID:109446972)
Posted: ‎2020-07-03 07:19 AM . Last Modified: ‎2023-10-22 01:46 AM
