Posted: β2020-07-03 06:41 AM . Last Modified: β2024-04-08 10:43 PM
When am I supposed to connect the DCO server to the Public LAN (Client server Network) and When I supposed to connect it to DCE Private LAN ?
(CID:108827461)
Posted: β2020-07-03 06:41 AM . Last Modified: β2024-04-08 10:42 PM
Hi Sameeh
I have always connected DCOs to DCE via the DCE Public NIC. FYI the DCE Private NIC is not IP routable and is designed for a stand alone monitoring network only - a great feature in cases where the customer has to pay for IP addresses and/or switch ports. You can build a stand alone "monitoring LAN"
Cheers
(CID:108827565)
Thank you very much ED π
(CID:108827577)
Posted: β2020-07-03 06:41 AM . Last Modified: β2023-10-22 01:45 AM
