DCO schows in alarm in DCE after upgrade to 8.2.2
  • DCO schows in alarm in DCE after upgrade to 8.2.2
126
65
Posted: ‎2020-07-04 03:07 PM . Last Modified: ‎2024-04-05 02:25 AM
949
I have upgrade DCO to 8.2.2 without any problem. The only problem is that now DCO shows in alarm in DCE
This is the DDF file that is using
I have requested the latest version of DDF file using the form online but I have been answered that the DDF file doesn't exit
I am missing something, please help me to get out of this confusion.
Enzo
(CID:129405742)
  • Data Center Operation
  • DDF
948
Hi Vincenzo,
This is indeed something that engineering has seen and is currently looking into. The DCO errors appear to be erroneous and hopefully we will have an update to this issue soon.
thanks,
Steve.
(CID:129405799)
Replies 6
Dear Vincenzo Fantino,
The latest version DDF-file for DCO-8.2.2 is v.5. This DDF-file is available for download on the same web page from which you downloaded the iso-file of the DCO-8.2.2 distribution. But it seems to me, that the problem is not in the version of the DDF-file, but in the DCO server itself. This must be checked.
With respect.
(CID:129405760)
Hi spezialist, first thing thank you for your fast answer 😀.
I have 3 server running same version and same database (prd, dev and test) and all 3 show the same error in DCE:
While if I check the Webmin the status for all 3 servers is OK
That is why I was thinking that the DDF file was the problem, infact the one that I have is version 4, that worked in DCO 7.5.0 . I am going to download version 5 and check if works.
Enzo
(CID:129405896)
949
Hi Vincenzo,
thanks,
Steve.
(CID:129405799)
Thank you Steve, please keep me update.
(CID:129405803)
Hi Vincenzo,
I do not have a date but the fix is going to be in the next DCO release.
Steve
(CID:129406721)
Posted: ‎2020-07-04 03:08 PM . Last Modified: ‎2023-10-22 01:45 AM
