DCO not displaying sensor values
  • EcoStruxure IT forum
  • DCO not displaying sensor values
125
65
Back to EcoStruxure IT forum
Mike-Sutton
Lieutenant Mike-Sutton
Lieutenant
Posted: ‎2020-04-16 07:19 AM
1699
Hi I have a client that I intergrated DCO with DCE the link is still fine but the DCO has decided to stop displaying the sensor values from a babel buster the DDF works fine on DCE showing all sensor values and did work fine on DCO untill a few days ago i have tried re-associtaion betwen the DCE and DCO but to no avail.
Has anyone else come across this issue if so how did you solve it.
TIA
MIke
  • Data Center Operation
Replies 6
Captain
Posted: ‎2020-04-16 12:08 PM
1692
Hello Mike, are the errors/message in the server.log file on the DCO server from the DCE server or the device itself? Can you share the server.log file?
Also, if you view the DCO device properties, click the external system entry in the left side pane. Are there values from the DCE device?
What you're describing sounds like the device itself it not being updated in DCO.
DCO uses webservices to collect data from DCE. I wouldn't expect a single device to stop working unless the device was somehow changed on the DCE side (i.e. lost comm, was deleted and rediscovered, and so on). But you already mentioned you re-associated the device so if it were deleted and rediscovered that action should resolve that.
Regards
Greg Sterling
Mike-Sutton
Lieutenant
Posted: ‎2020-04-22 01:49 PM
In response to gsterling
Hi Greg thankss for you response i will try and get the log files, everything is perfect as excpected in DCE thats whats thrown me?
Cheers,
Mike
Mike-Sutton
Lieutenant
Posted: ‎2020-04-23 06:11 AM
1654
Log files attached
application.log
Captain
Posted: ‎2020-04-30 04:22 AM
In response to Mike-Sutton
1626
Hello Mike, can you also share your server.log file from your DCO server as well?
Regards
Mike-Sutton
Lieutenant
Posted: ‎2020-05-15 04:35 AM
1554
Hi These are from the DCO? Do you mean the DCE??
Mike
Captain
Posted: ‎2020-05-15 05:12 AM
Hello Mike. The log file you sent (application.log) is more of a DCO client log and not a server side log.
From the webclient can you download logs from the administration menu so the server side logs for DCO can be included?
Regards
Greg Sterling
