DCO available asset properties descriptions
  • EcoStruxure IT forum
  • DCO available asset properties descriptions
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 07:45 AM . Last Modified: ‎2024-04-10 01:40 AM
1103
1.Do we document this list of  the default 37 asset properties, somewhere in documentation?
Will also need its description and usage: whether it is optional, automatically entered by DCO or something applicable for specific use only, e.g Blade chassis
This article provide details to some properties.
How to import data in to StruxureWare Operation
2.How do we update these existing properties using excel import?Not all 37 of properties are in excel template.
For example using 'CP IP Address' resulted in a new custom properties being created instead of updating the existing IP address property.Adding a column called 'IP Address' does not update either.
Thanks!
(CID:89063436)
  • Data Center Operation
1103
Hi Christopherus,
Regarding question #1
The asset properties are described in the following page Asset properties description
Hopefully this answers your question otherwise please let me know.
Regarding question #2
The excel importer is not intended to be used for updates of properties. Only for first time entries.
In this case the lack of description of the default properties hides that the IP address is a network property.
The reason for not using excel importer for updates are the fact that the excel importer will delete and re-add the asset. It will not do an update on existing equipment. This means all other information than entered in the excel sheet will be gone. Also traceability in audit log etc. will be gone.
(CID:89063788)
Replies 7
Hi Christopherus, we will look into it, thanks for sharing.
(CID:89063554)
Please consider posting each question individually, it makes it easier for someone to answer and for other users of the site to search and find the information they need. Thanks!
(CID:89063614)
Hi Christopherus, Ad 1) I'm working on documenting the default properties list and will get back with more information shortly.
(CID:89063786)
1104
Hi Christopherus,
(CID:89063788)
Thanks. Will separate questions next time. On asset properties, found it on the new description: http://dcimsupport.apc.com/display/UAOp74/Asset+properties+description
(CID:89063808)
Great you found it already 🙂 This is however work in progress. I will post once done.
(CID:89063816)
Posted: ‎2020-07-02 07:46 AM . Last Modified: ‎2023-10-31 10:48 PM
This is a heading
