Posted: 2020-07-04 01:01 AM . Last Modified: 2024-04-05 04:17 AM
We have been experiencing slow performance on our DCO server recently. After checking the Webmin page, the virtual memory is full utilised. Is this affecting performance and if so how do I increase it?
The physical server hasn't changedand there seems to be plenty of RAM left.
I have checked the Jave version and it is running the following, don't believe that is affect by the recent issue.
1:1.8.0.121-0.b13.el7_3
Is there any other troubleshooting I can do?
(CID:126167356)
Hi James,
You can try to do some troubleshooting from the ssh-console.
At first, run the top command, then press the f key (to open Fields Management) and in the list that appears, use the arrow keys and the spacebar to select the SWAP field. After this field is marked with an asterisk, press the q key. A table with processes appears again, but with a SWAP field. Now press Shift+M to sort by size. At the first line, you will see the process that most occupies virtual memory (swap partition) of you DCO-server.
Secondly, you can try to clear the virtual memory. To do this, you must first run the swapoff -a command, and then run the swapon -a command. After that let the DCO-server work for several days, and you follow the state of its virtual memory.
Only after that you can think about further solving your problem.
I was glad to answer your questions.
(CID:126167492)
Posted: 2020-07-04 01:02 AM . Last Modified: 2024-04-05 04:17 AM
spezialist - Thanks for the instructions, see screenshot below of the process using the most virtual memory.
I had done the
sudo swapoff -a && sudo swapon -a command as per this thread last week. The VM went down but then went back up an hour or so later.
(CID:126167684)
Hi James,
I.e., your screenshot confirmed my assumptions 😀.
You said that you already did what I asked for. Should I understand that this did not help you and the problem still remains?
I understand correctly, do you have DCO-8.1?
P.S.: did you perform any updates to your DCO-server?
(CID:126167717)
spezialist After running the command last week it didn't make much difference and is still slow and yes DCO is 8.1.
No updates on the server since upgrading to 8.1 April/May time
(CID:126167728)
Ok, and when did you start to pay attention to this problem?
With respect.
(CID:126167732)
spezialist - It's only been the last week or so. Also noticed the web client takes a little longer to open as well.
(CID:126167742)
Screenshot showing memory useage, I assume that shows what happened when the command was run and as you can see it is climbing back up, almost 80%
(CID:126167752)
Hi James,
I spent a bit of time finding similar problems here on the HELP CENTER EcoStruxure IT, for example, topic . And I concluded that, if after your DCO-server reboot your problem is not solved, then it's very likely that you will have to perform a clean installation of DCO-8.1 and restore on it a previously made backup...
(CID:126167987)
spezialist Thanks for your help on this, I hope it doesn't come to performing a clean install.
(CID:126168163)
Hi James,
Thanks for the feedback: I'm also very interested in how your problem will be solved.
(CID:126168203)
Posted: 2020-07-04 01:03 AM . Last Modified: 2024-04-05 04:17 AM
I come across this before and it remains unresolved.... I am also interested to know how to solve.... a clean install is a nightmare to me.......................
(CID:126168244)
Hi James,
Virtual memory usage doesn't seem to mean anything here, since you have plenty real memory available. Your Java version seems to be older than the affected version, so I'm not expecting memory-leak problem here.
However, I was wondering if it is possible to ask for
1) detailed description of the problem (including screen captures, date/time of the problem).
2) server logs + client "application.log" file (if you see the problem on client(s) side),
3) latest copy of the backup file
Kind regards
(CID:126167557)
Jef Faridi - Have uploaded the files as requested. Haven't got any screen caputes as it was a case of clicking and the client having the Not Responding screen (where it whites out).
This was happening last week with it being especially bad on Thursday/Friday.
(CID:126167777)
Dear James,
Have you been able to solve this issue or not?
With respect.
(CID:126171038)
spezialist Waiting on feedback from Schnieder after uploading log files and backup.
(CID:126171100)
Posted: 2020-07-04 01:03 AM . Last Modified: 2023-10-22 01:42 AM
