DCE HDD
  • DCE HDD
129
72
Posted: ‎2020-07-04 01:01 AM . Last Modified: ‎2024-04-05 04:18 AM
1056
DCE HDD
Hi
i would like know if i want add new HDD in dce can i do that ?
for example  : if my server HDD fail can i change HDD?
(CID:126167103)
Posted: ‎2020-07-04 01:01 AM . Last Modified: ‎2024-04-05 04:17 AM
Hi Hojjat,
If you have a hardware server and the drive fails under warranty, you should contact APC tech support for a replacement drive or, if none are available, a new server.
If you have an out of warranty server, I suggest replacing the drive with a similar one. We use Dell servers and the Dell service tag on the server should provide the info required.
Steve.
(CID:126167111)
Hi Hojjat,
Steve.
(CID:126167111)
Posted: ‎2020-07-04 01:01 AM . Last Modified: ‎2023-10-22 01:17 AM
