DCO - StruxureWare Operation failed to upgrade to 8.2
  • EcoStruxure IT forum
  • DCO - StruxureWare Operation failed to upgrade to 8.2
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 02:32 AM . Last Modified: ‎2024-04-05 03:48 AM
924
I running the following version:
StruxureWare Data Center Operation Server: 8.0.1-65671-5874f3
and started to upgrade to 8.2 based on the documentation:
http://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/Getting+from+previous+versions+to+DCO+...
(section Upgrading using the latest 8.x iso file)
It failed because of the following reason:
Operations::UpgradeManager::cleanupAndExit Upgrade failed with: Build info did not match installer. Expected: 4fae33c7c80c457f0e1277cb607f362d3d8d4b29 Got: 5874f3e3e97282375f22f6f54aa460d76e77b477
(CID:126182470)
  • Data Center Operation
Posted: ‎2020-07-04 02:32 AM . Last Modified: ‎2024-04-05 03:47 AM
925
Hi Mate,
I think it is most likely the DCO server is unable to access & download packages from the Internet (during the upgrade process), so you might want to:
1- Trying the upgrade by checking the option "Do not download packages from the internet":
If that shouldn't help, then:
2- Make a clean 8.2 installation, and then restore a fresh backup from the current setup (8.0.1).
Kind regards
(CID:126182496)
Replies 4
926
Hi Mate,
Kind regards
(CID:126182496)
Thanks Jef, option 1 solved my problem.
(CID:126182580)
Posted: ‎2020-07-04 02:33 AM . Last Modified: ‎2024-04-05 03:47 AM
You are most welcome, Mate
Excellent, many thanks for the update,
Kind regards
(CID:126182585)
Posted: ‎2020-07-04 02:33 AM . Last Modified: ‎2023-10-22 01:40 AM
