How to transfer Notification Policy between two independant DCE?
  • How to transfer Notification Policy between two independant DCE?
129
72
Posted: ‎2020-07-04 02:32 AM . Last Modified: ‎2024-04-05 03:48 AM
970
We are holding two fully separated DCE. However, we would like to use similar Notification Policies.
How can we export the defined Notification Policy from DCE #1 and then import them into DCE #2 ?
Hervé
(CID:126182373)
Replies 5
970
Hi Herve,
sorry but there is no way to export a notification policy by itself. If you wish to have a similar policy on a different server, it must manually be recreated.
Steve.
(CID:126182383)
Thanks for the quick answer. Well understood.
Next feature to create may be ?
Hervé
(CID:126182533)
Hi Herve,
You can put in an enhancement request under the main menu on this page under"Resources"–> "Feature Requests". I'm not sure something like this will make it into the system however as I believe in most instances, people only have one or 2 e-mail addresses. If you feel that your configuration is a little more difficult to reproduce, perhaps a little example when creating the feature request may help.
Steve
(CID:126182537)
Enhancement requested. Thanks.
(CID:126183956)
Posted: ‎2020-07-04 02:32 AM . Last Modified: ‎2023-10-22 02:35 AM
