Posted: 2020-07-05 05:22 PM . Last Modified: 2024-04-03 03:23 AM
Hi professionals,
Is there an option of searching for this window in DCO? If not, is there someone like this in development?
Sheep 😀
(CID:140219601)
Hello
What is happens when you press to column name ?
(CID:140219685)
You are correct that view is not searchable ... but the network cable browser pane to its right can be searched/filtered which means you can search for actual connections. It does not however help you with "free" port searches.
Regards
Greg Sterling
(CID:140711810)
Thanks!
(CID:140711812)
Posted: 2020-07-05 05:22 PM . Last Modified: 2023-10-22 01:39 AM
