Posted: 2020-07-04 07:15 PM . Last Modified: 2024-04-04 11:16 PM
Hello
I try to manage users via the Active directory .For this I have created 2 groups (dcoadmin and dcousers ). It's work on my lab perfectly when groups and users location are in USERS container into Active Directory.
Unfortunately in customer users location into OU of the HR and groups into a different container than USERS . This AD topology doesn't work . I got to receive the very starnge error that user or password is incorrect. In jboss log I don't see any requests to AD .
I attach my configuration.
(CID:132654296)
Hi Boris,
Based on your screenshot your groups are located in dcoap02.dcoCon.trick.com
your users are located in users.trick.com
and you authenticate with a user called "admin"
I recommend verifying that this is correct, i normally use a tool like Apache Directory Studio to connect and verify my Active Directory.
The error message you are getting indicates that one or more of your domain/username/password/"username attribute" and user search base are incorrect
What version of DCO are you running?
Could you possibly send a screenshot of the error message when i occurs?
Regards
Martin Bertelsen
(CID:132654312)
Hi Boris,
Regards
Martin Bertelsen
(CID:132654312)
Hello Martin
I'm working on DCO 8.2.2
it's correct that I written. The user admin that bind to AD is located into CN=USERS . The group dcoadmin into CN=dcoCon . I'm using other ldap tool for check ldap path.
In server.log of the jboss clear
(CID:132654332)
This in my lab and I can to do what I want .
(CID:132654335)
Your user search base is "CN=USERS"
you are trying to log in with a user "agaf" whom is located in "OU=MyUsers"
The user search base is where you fetch users from when synchronizing ("CN=MyUsers"), not necessarily where the user who authenticates the AD server itself is located.
Try replacing CN=USERS with OU=MyUsers
Regards
Martin Bertelsen
(CID:132654360)
many thanks
I'll try and notify to you
(CID:132654399)
Many thanks Martin
You are right - it's working .
Many thanks
(CID:132656505)
Sounds great! you are welcome 😀
(CID:132656515)
Posted: 2020-07-04 07:16 PM . Last Modified: 2023-10-22 01:39 AM
