Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-02 10:03 PM . Last Modified: 2024-04-09 01:34 AM
Felix
(CID:105459956)
Felix,
Are all of the license keys for the same server that are listed within that screen capture? if they are, I will consolidate them to be all underneath one base DCO asset.
If you look closely at the license keys that you copied out of the web interface, there were be a space in the license key, similar to:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXX
Copy and paste the license key into a notepad program, remove the space, and then try to install it on the server.
(CID:105459961)
Felix,
(CID:105459961)
There is also an option to export the License Keys which were generated in an excel file to avoid any type error.
I hope that this helps.
(CID:105459986)
Posted: 2020-07-02 10:03 PM . Last Modified: 2023-10-31 10:50 PM
