DCO License removal
  • EcoStruxure IT forum
  • DCO License removal
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:10 AM . Last Modified: ‎2024-04-10 12:59 AM
891
DCO License removal
How to delete some licenses from DCO especially when we run POC (Proof of concept) for some customers. Sometimes they ask for a month extension and we don't want to give extension for IT Optimize or power control but only renew Operations, change or Capacity.
(CID:93914066)
  • Data Center Operation
891
1)      Browse to your server’s license key page with the below command
http:///clients/handleLicense/?action=listDetailed
EXAMPLE: http://192.168.1.100/clients/handleLicense/?action=listDetailed
2)     Review the licenses installed. You will see something similar to what is below:
StruxureWare Operations, 10 racks license, expires 1/11/12 (6801756BD1D198CDEADEB115C2F21106149351BAB19773489F12E9F3818983DF)
3)  Remove the unwanted or expired licenses with the below command
http:///clients/handleLicense/?action=remove&key=
Example using the first Operations 10 Rack license above
http://192.168.1.100/clients/handleLicense/?action=remove&key=6801756BD1D198CDEADEB115C2F21106149351...
(CID:93914317)
Replies 5
Hi, we will look into it in week 2, 2015. Thanks for posting.
(CID:93914096)
Hi Shemil,
The case you are describing you should use license keys that has an expiration date.
That is the general way of handling cases where only parts of the software should be available for a given amount of time.
(CID:93914165)
892
(CID:93914317)
Thank you John and I was able to remove the expired licenses
(CID:93914478)
Posted: ‎2020-07-02 10:11 AM . Last Modified: ‎2023-10-31 10:50 PM
This is a heading
