Posted: 2020-07-05 01:53 PM . Last Modified: 2024-04-04 12:21 AM
Hello!
I tried to add a rack via assets rest api but I failed, as adding to the room is not supported.
I need to add racks to rooms not via UI.
Maybe there is some patch or fix that will enable to do it with the help of public api?
Or maybe there are any other variants that will make it possible to add equipment to the rooms not with the help of the desktop app.
Are there any ways to resolve my issue?
(CID:134695896)
Hi Vladislav
You could try the DCO Excel import feature but I'm not sure if you can place exactly racks
Cheers
(CID:134696007)
Hi!
Thanks a lot for your answer, but I think that it is not what I need, as using this feature also needs human involvement.
I need something like assets rest api where I can send parameters and the service will add the rack automatically.
So, if there are any other ways or workarounds of my issue, I will be glad to consider them.
(CID:134696022)
Posted: 2020-07-05 01:53 PM . Last Modified: 2023-10-22 01:38 AM
