Posted: 2020-07-02 10:54 PM . Last Modified: 2024-04-09 01:18 AM
Has anyone got any experience creating the DCO 7.5 ETL Export DB on SBO Reports Server (MS SQL Server). Thanks
(CID:105461840)
Hi Ed, not specifically on SBO Reports Server but I have successfully created and used SQL Server as staging db, please follow the 'External Database' instructions on ETL Database Configuration page.
That said, I would not recommend hosting SBO Reports Server and DCO staging db on the same SQL Server installations, we've seen issues with upgrades and outages when db instances are shared across PME and SBO. If this is for testing/demo purpose, you should be fine, but these databases should be separated out for production.
(CID:105461885)
(CID:105461885)
Posted: 2020-07-02 10:54 PM . Last Modified: 2023-10-31 10:49 PM
