DCO - ETL Database Integration - Export
  • DCO - ETL Database Integration - Export
129
72
Posted: ‎2020-07-04 05:05 PM . Last Modified: ‎2024-04-05 12:02 AM
1713
We have configured a DCO internal database export and so that our other server can connect to it and extract it on daily basis for report generation and analysis.  I have reviewed the documentation below and have been able to configure it successfully.
We are able to connect to it using the configured user id and password and can see all the schema tables.  However, there is **no data** at all in all tables.  Can you advise what could be wrong and if there is anything else we need to do?
http://sxwhelpcenter.ecostruxureit.com/display/public/DCIMDEVELOPER/ETL+External+System+Configuratio...
(CID:130681519)
  • Data Center Operation
1714
Hey YJ,
Had a time to finally go thru that.
You need to wait till the scheduled export time for data to show up, earliest is 1 hour.
Below are my test using the default ETL export scripts in DCO.
Steps
  1. Create ETL Export Out
  2.Set ETL external system in DCO
3.Connect using pgadmin
4.After the specified scheduled amount of time:
Troubleshoot connection issue
Follow steps here:
http://sxwhelpcenter.ecostruxureit.com/display/DCIMDEVELOPER/ETL+-+Change+allowed+IPs
Range of ip address filter, e.g 0.0.0.0/0
http://sxwhelpcenter.ecostruxureit.com/display/DCIMDEVELOPER/Configuring+network+connections+in+the+...
(CID:130681551)
Replies 7
1715
Hey YJ,
Steps
Follow steps here:
(CID:130681551)
It is working now, thanks Chris.
(CID:130682900)
Posted: ‎2020-07-04 05:06 PM . Last Modified: ‎2024-04-05 12:02 AM
1714
You can also run the export on demand.
Planning - Device Association - ETL Integrations
Right click the desired External System and select run now.  See Setting Up an ETL Configuration
"Run now! will run the transformation and update the database accordingly."
(CID:130682094)
There isn't a "Run now" button on my windows client.
(CID:130682904)
Posted: ‎2020-07-04 05:06 PM . Last Modified: ‎2024-04-05 12:01 AM
Apologies, it's called "Synchronize external data".
(CID:131958792)
Thanks Ed, found it now.
(CID:131964915)
Posted: ‎2020-07-04 05:06 PM . Last Modified: ‎2023-10-22 01:37 AM
