Posted: 2020-07-03 02:05 PM . Last Modified: 2024-04-08 01:25 AM
If you have to configure your network settings by hand,
during the installation process enter the “Network & Host Name” configuration:
Ethernet option “OFF”, and press the Configure button:
In the Ethernet connection settings, select the Device that contains MAC Address:
In the IPV4 Settings, enter IP address, netmask, gateway, dns, and then Save:
And now press the Ethernet button “ON”, and then Done:
That’s it.
(CID:114233340)
Thanks for sharing 😀
(CID:114233627)
Posted: 2020-07-03 02:05 PM . Last Modified: 2023-10-22 01:34 AM
