DCO 8.x how to generate SSL CSR?
  • EcoStruxure IT forum
  • DCO 8.x how to generate SSL CSR?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 08:18 AM . Last Modified: ‎2024-04-08 03:55 AM
928
i have customer that would like to use their own ssl cert, part of that process requires generating a certificate signing request.  DCE already has a wizard in place to do this.  Is there something similar in DCO?  or if possible, can someone provide the commands to use with openssl in the linux backend?
(CID:110005865)
  • Data Center Operation
Replies 7
Hi Andrew Trabert, thanks for posting. Lets see who can be of assistance here. @community any ideas? Kind regards Ditte
(CID:110006088)
928
Hi Andrew
Have you had a look at the following?
https://dcimsupport.apc.com/display/public/UADCO8x/Changing+SSL+certificate+on+the+server
Many thanks
Martin
(CID:110006178)
Hi Martin, Yes I've seen that page, however that still doesn't provide any info on how to generate a signing request. The whole reason we need the CSR is because their security scan software flagged the DCO server for using a self-signed certificate. DCE has a whole wizard for generating the CSR Modifying the SSL certificate and I've seen some documentation online on how to generate a CSR using the CLI and openssl. However I'm looking for some official supported documentation/procedure on how to use openssl to generate the CSR or some other method.
(CID:110006194)
This website will contain the information you require, https://www.openssl.org/
(CID:110006200)
I'm sure it does and I know it's not that difficult. However given that the wrong ssl cert can break access to the server, if possible, I'm looking for a supported procedure from SE instead of trying to figure it out myself.
(CID:110006201)
here's the response i got from tech support.
log into the linux backend and run the command
"sudo openssl req -new -newkey rsa:2048 -nodes -keyout server.key -out server.csr"
then use winscp or the upload/download function of the webmin console to download the server.csr file.
after that you can generate your ssl cert and import it following SE standard ssl cert import process
(CID:114822492)
Posted: ‎2020-07-03 08:19 AM . Last Modified: ‎2023-10-22 01:34 AM
This is a heading
