DCO 8, search functionality equipment browser
Showing results forΒ
Did you mean:Β
  • DCO 8, search functionality equipment browser
129
72
Posted: β€Ž2020-07-03 08:31 AM . Last Modified: β€Ž2024-04-08 03:50 AM
1056
All, since version 8 we notice a difference in the search functionality within the equipment browser, before 8 when you searched for a device within a "not loaded" room it was shown as grayed out but now the device is not even found, unless you load all the rooms. Is there a special reason for this change or did I miss something
(CID:110006550)
  • Data Center Operation
Replies 5
Posted: β€Ž2020-07-03 08:32 AM . Last Modified: β€Ž2024-04-08 03:50 AM
All, did find this question: Search function in DCO 8 is a big step backwards... end this exactly describes our issues, we cannot even export now on a search when a room is not open, if possible this really has to be fixed asap
(CID:110006561)
1055
Hi Cees,
It seems you already have seen the answers provided by our product manager in another community post πŸ™‚ ,  however if you wish I can capture a feature request for you/customer? thanks.
Kind regards
(CID:110007003)
Hi Jef, I was to quick to accept the answer, I have seen the other community post but the answer is not acceptable for my customer, we need this search option, it is not acceptable that a option that first was available is removed because of a performance issue and then left out in future releases. I think the performance issue needs to be fixed so we can search again in open & closed rooms. So yes please create a feature request.
(CID:110007047)
Hi Cees, This feature request is now registered for you/customer, thanks. Kind regards
(CID:110007048)
Posted: β€Ž2020-07-03 08:32 AM . Last Modified: β€Ž2023-10-22 01:34 AM
