DCO 8.2.7 upgrade to 8.3 failed
  • EcoStruxure IT forum
  • DCO 8.2.7 upgrade to 8.3 failed
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 09:05 PM . Last Modified: ‎2024-04-03 12:59 AM
945
(CID:147199816)
  • Data Center Operation
Replies 5
same issue on this post
(CID:147200847)
945
Hi Lukas,
Do you know if the server is able to access the internet during the upgrade process? if not, then that may be the reason why upgrade is failing. This has been a know issue and the near future release expected to contain the fix. However, for the time being I would suggest a clean 8.3 install and then restoring the latest fresh backup file.
Kind regards
(CID:147201516)
Hi Jef, the Internet is completely open. Did you try an upgrade with the provided backup and look at the logfiles?
Best Regards
Lukas
(CID:147203727)
Hi Lukas,
What backup file are you referring to? I have not received any description or data about this case/post.
Kind regards
(CID:147203729)
Posted: ‎2020-07-05 09:05 PM . Last Modified: ‎2023-10-22 01:33 AM
